OK, here are the pics. I made a boo boo today. The question is, is it fixable? Second, I did drive it while it was like it was, but imediately turned around, since there was a severe vibration. Is that from the damage done to the prop? If not, then what should I go have checked out. The prop and shaft still spin by hand, so I think they are ok. If I need to get a new one, what are my options? What are some advantages to 4 and three, and what pitch should i get? I mainly do wakeboarding, with weight, and some heavy boarders/skiiers. Thanks for all the info. Oh yeah, where can I get these props at, and is there anything to them to pull them off, I Mean just loosen the bolt, and then what? Thanks everyone.
Dom
Dom
looks like you were in reverse when you did it? That being the case... you probably werent going too fast when you did it and probably didnt damage anything but that poor, poor propeller. I would assume that its fixable, but you should think about gettin' a spare. I'm thinking you may have to send it to acme, since it's CNC machined in the first place.
