I took my 20V out for the 2nd time yesterday and I am now hearing a quick squeek from the trans. or somewhere around there. It happens about 1 to 2 seconds after the engine starts. Can anyone help? Is there sonthing I can lubricate? and, Is this somthing I sould be concerned about? Thanks.
Start Up Squeek
Is the boat in Gear?
If so check all the shaft seals.
There are not many things that can squeak at that location.
You have small shaft coming from the transmission, and going to the V-Drive.
There is a second shaft coming out of the V-drive going through the hull off the boat.
There are a total of 4 seals. (The seal going through the hull is a different type then the others.)
I have had this happen to the transmission on a Saturn before. It would squeak for a few seconds when you started to drive it, and then it would be quiet till the next day.
If the shaft seal going through the hull is too tight (not getting wet) it might squeak,
Again this would only happen when the boat is in gear.
If the squeak happens before you put the boat in gear, there is nothing that I can think of back there that would do that, everything is in the front of the engine like the other said.
You will probably need to run the boat with some of the cover s off and the engine hatch open. Have somebody else start the boat while your listening for the sound.
Good luck
DavidLast edited by whitlock87; 01-23-2006, 03:40 AM.Tige, it's a way of life!
With the boat out of gear this eliminates the drive train. I would check the belt first. The other item could be the impeller after sitting so long it has dried out and once it starts getting the water circulated it will stop. How long since you used the boat last and what motor is installed. If you want to pm me that info that will be great or give me a call 325-676-7777.
Andrew
I had a thought.
After your done for the day, do you run the engine after you pull the boat out of the water?
If so you could removing all the water from the pickup pump.
It would dry up, and the next time you start the engine it might make some noise until the water starts to flow.
If so try not running the engine after you pull the boat out of the water.
(I personally never run the engine out of the water)
DavidTige, it's a way of life!
Thanks for all of your help.
