So I semi-successfully changed the impeller in my '08 20V (Marine Power) over the weekend. While cranking down on the last of the 4 bolts on the housing, I got a little too popeye with it and busted the damn head off. With the 3 others tightly on there and the gasket, it looks like it still might be pretty air-tight. I don't really want to take the entire pump off to try to remove what remains of the screw, but I guess it may be inevitable. What are the risks to running the boat as-is? If I don't see any water leaking out back there, am I ok?
Broken Bolt on Impeller Housing...
Tigé Jedi- Jul 2010
- 3795
- TN USA
If it broke off at the head, leaving some bolt shaft sticking out of the threads, you should be able to get some pliers or vice-grips on it and just unscrew it out. Then use four new, matching, high grade replacements. I had this happen on a previous boat's engine and by removing the accessory the remainder of the bolt was just sitting there, easy to grab and remove.
It would bug me every day until it was fixed properly. Just do it now, so it's done on YOUR offseason schedule.
we had a guy that used to work for us that broke atleast one of every week. If you just take the other 3 back off and remove the cover you should be able to just twist it by hand. We never had a problem getting the broken piece out. The problem you will have is finding a replacement one for the broken one. We always kept them out of pumps we replace because this guy would break them all the time. Good Luck.
LEDs look great
I agree with the above comments. If its not broken flush with the surface of the pump body, they should be able to grab hold of whats left and spin it out. It should not be too tight as it was already out and was just reinstalled.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
cool...thanks for all of the replies. it sounds like the general consensus is that i need to fix it. i haven't actually tried removing the cover yet since i was selfishly hoping to ignore it, but ill take a peek today and see what if anything remains exposed from the broken screw.
any idea where to find replacement screws? do they need to be brass or could i go with something stronger like stainless? thanks again for convincing me to do the right thing!
Tigé Jedi- Jul 2010
- 3795
- TN USA
Use the same material if possible to avoid galvanic corrosion. If not possible, use something as close as possible on the triboelectric scale.
Do you have a local Fasteners store? They carry almost everything....
do try a left handed drill bit firstOriginally posted by travis5550 View PostWell I opened up the housing today to reveal yet another annoyance - the bolt broke off pretty much flush with the housing - meaning there is nothing exposed for me to grab on to and extract. I guess I am going to have to start drilling..."Failing to prepare is preparing to fail" John Wooden- Rest in Peace
