It doesnt spring at all it is a screw, there is an electrical motor in side that turns the shaft and moves it in and out, if it was open and stuck there when you started the motor it would be racing fast idle.
IAC Valve Functioning Properly?
k.. well the idle seemed fine so I am just going to do the spark plugs and cap and rotor while im messing with the IAC... should the distributor be replaced too? those things aren't cheap...Originally posted by dom w. forte View PostIt doesnt spring at all it is a screw, there is an electrical motor in side that turns the shaft and moves it in and out, if it was open and stuck there when you started the motor it would be racing fast idle.
