We are getting an engine alarm while surfing on our 09 RZ2 with the 409 hp PCM motor.
The boat never goes into limp mode. The first few alarms were at Norris a few weeks ago while surfing. The engine was also surging some afterwards. Fuel filters were clear. I attributed it to bad gas perhaps.
After that trip, the dealer flashed the 409 PCM with new software from PCM thinking that may address the issue. We also had our 150 hour service so fluids were checked.
This past weekend was the first time with the engine flash. After surfing about an hour, the engine alarm sounded again when the rpms were coming up but before we reached surf speed. I did not feel any loss of power or surging of the engine.
I shut the boat off and let it sit. Turned it back on and cruised slow with no engine alarm. Speed up towards 10.6 mph and got the alarm again before reaching speed. Tried that once or twice more with the same result.
Drained the tanks and did hole shots and cruising with no ballast and never got an engine alarm. We did no further surfing and got no more engine alarms.
Anyone else have a similar issue?
The boat is at the dealer and I will update with any results.
