Transmission slipping out of gear
    I cannot get any traction on answers in another post about this. SRK99 asked the same issue I am having but there is never a follow up so I am not sure. Boat was fine all summer. Went for a ride Saturday and it comes out of gear. My start battery was weak and the house battery was in the garage on the charger so maybe that battery could have been an issue but I drove it for over an hour and it would continue to do it. I have video but I guess we cannot upload videos here. Engine running fine. Trans seems to shift into gear fine but when accelerating it acts as if it is coming out of gear. I believe at one point I went to adjust the tabs with the touch screen and it did it. I also noticed when I turned on my blowers my cockpit lights flicker and one time went out completely. These are new batteries this season. Maybe I did not use the boat enough. Should I test with a different set of batteries? I have fought other electrical issues over the years with this boat. I had it ironed out pretty good until this.
    Could it be something with drive shaft slipping under load or prop issue?
      Update on this. Charged batteries. Pulled shift valve and inspected screen. Was advised to swap solenoids on the shift valve but that resulted in forward reverse behind swapped. Also changed my trans fluid. Ran great this weekend.
