Anyone with similiar hull have data on how changing to the 1235 from a 537 affects your top end?
Acme 1235 top speed on 08 22Ve
How fast do you want to go? I can't speak to the top end specifics of your boat but I dropped to a 13.75 pitch prop and loved the change and can still run slalom speeds. I've considered dropping the pitch even more as the improvements were so great on what we do 99% of the time.
Sent from my SM-S911U using Tapatalk
You’ll still be able to hit to hit 35 but your RPMs will be topped out. I cruise with my RPMs at 3k and get about 25mph.
The 1235 is a great blend of hole shot and top end with emphasis on hole shot. It’s a massive improvement over the 537 if you’re planning on hauling any kind of weight and want the boat to plane out quickly.
I too rarely run at the top end. My boats GPS verified top end is 41-43mph depending on conditions with a few people. I ask to get an idea how cruising speed might be affected too. I hate to drop the top end under 40 because I like to cruise around 30. With that being said, I do find myself cruising at lower speeds with my Tige than I did with my Regal.
Regarding BCRider's results, that i could definitely live with for the improvements the 1235 would offer.
Sometimes I find myself needing to get from one end of the lake to the other, at those times speed is something to at least consider.
If I knew I would have a comfortable cruise of 25 and a "in a bit of a hurry" cruise speed of 30. I'd be happy with that.Originally posted by BCRider View PostYour top speed goes from 44 to about 41. That being said I rarely ever put my boat flat out. Usually, cruise at 25 maybe 30.
BCRider, does your boat have the same hull design and powerplant as the 2008 22ve?
