2007 24VE Throttle and Speedometer
    I took the boat out today for the first time. I ran fine for 10-15 minutes and then while planed out it went to an idle and would only idle. I plan to replace the fuel filter. Any other suggestions?
    Also, the analog and digital speedometer both read 0. Where should I start with this, paddle wheel?
    Thanks in advance!
    Sounds like a limp mode problem. As suggested in this forum, I replaced the TPS (Throttle position sensor). Check out this thread. https://www.tigeowners.com/forum/tec...d-calibrate-it
    Don’t be intimidated by this. Following the instructions, it was very straightforward and worked perfectly! Good luck.
      I had an 06 and it dropped into limp mode like that with some bad gas.
        Does anyone know of a cheap scanner for the MEFI-5a system?
          I ordered a new fuel filter and the TPS sensor and I am patiently waiting for them to arrive before the holiday weekend! Old TPS already removed.
          So there is no MEFI fault reset required after replacing the TPS sensor?
          Thanks for your help!
