Does anyony know if the impellar on a 2008 RZ2 340hp spins in a clockwise or counterclockwise direction if you were looking at the impellar from the rear of the boat, that is if you could actually get there as it is seems entirely impossible to get in to this position. Thanks in advance for any help you may have to offer.
Marine Power Impellar change
Supreme Tigé Master- Sep 2005
- 8882
- 2005 24v
I changed Coaches impeller in this RZ2 on the water and I believe it spins clockwise.
BTW if you have to change an impeller with the boat in the water...good luck.Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
- 8882
- 2005 24v
That was not the problem, it was the fact that water was pouring into the bilge once we opened it up.Originally posted by xpjim1 View PostOr be shorter than 6'8"Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
