I've got a lot of work to do. I've only just started on engine oil and brake fluid change and have checked the prop shaft:
- Teak-oil swim step
- Wax and detail boat
- Change Engine oil and filter
- Change Fuel filter/water separator (after first start)
- Change Distributor cap and rotor
- Inspect spark plugs (new last year)
- Check battery water level and test cells
- Replace sea water pump
- Tighten / inspect serpentine belt
- Check V-Drive oil (new last year)
- Check transmission oil (new last year)
- Check prop shaft alignment (was perfect)
- Replace steering cable
- Inspect throttle cable
- Verify running lights, horn, dash lights, etc.
- Test TAPs
- Test bilge pump
- Put together first aid kit
- Verify flares/signal horn, life jackets, throw cushion, etc.
- Finish wiring tower speakers
- Inspect trailer brakes
- Change brake fluid (looked OK at calipers, but like rusty chocolate milk at master cylinder)
- Repack wheel bearings
- Inspect trailer lights
I only use the boat for 30hr a year do I realey need to change motor and v drive fluids each season.
