Where can I find stainless stell Gas spring/shock mounting brackets ?
    I have an 03 21r and all of the mounting brackets for the gas shocks are rusting. I have found some stainless steel on the internet but the mounting balls come in several sizes. (10, 13 & 16 mm) does anyone have an idea of the size comes stock on the boat.
    Thanks
    If you find out what size, if you would let me know b/c I have some that have rusted out for the engine cover. aaron3865@earthlink.net
      I thought that tige put all stainless steel harwarde and fasteners or are these items excluded.
        SS Gas Springs
        I know this thread is old - but I took some time to find a replacement gas spring on my Z1's engine hatch. They Tige OE parts on mine are from Ameritool. There is a number - 625-7-90 which is the part number.
        Maxum Hardware in Ohio, and Lewis Marine handle these. I found my P/N on the Maxum website and ordered from there. The last number is weight - so spring is rated for 90 lbs. And the wind can still blow them shut - so I am going to make a support to keep both hatches open when I am drying out the bilge etc.
          http://www.tigeowners.com/forum/show...ght=gas+shocks
