Glove box cover in 2000 2100v limited
    The rubber padding on the glove box cover is damaged and peeling off. What is the repair options or corrections for this. Thanks
    Do you have a picture?
      I’ll have to get one this weekend as I am traveling. The glove box lid is covered by 1/8” thick soft rubber material and it has peeled off
        Take it down to an upholstery shop. They should be able to fix you up.
          They were a custom cut part. Basically a rubber foam material with a sticky back. You may be able to go with an off the shelf foam rubber seal to get you by. I believe lowes/home depot carry stuff like that.
          Oh Yeah!
            Thank you for the advice.
