Hey! I'm winterizing a 2015 Z30 with base 6.2L Raptor and plug n play additional ballast. Wondering a couple things.
1. First did I drain everything I need to?
2. Also, how do I fill the fresh water system with antifreeze?
3. How do I add antifreeze to the ballast system?
4. Listed what I've done below. Have I missed anything?
What I have done:
1. Pulled drain plugs and impeller for fresh water system.
a. I pulled a brass plug from hose going into the heat exchanger from the water pump
b. I pulled the brass plug/node from the heat exchanger
c. I pulled the hoses that cross from the manifold apart from the Center fitting and drained
d. I pulled the brass plug/node from the front of the V-drive.
e. I removed the fresh water pump impeller. (Inspected - It is. Little hard so will replace in spring)
2. Oil change was done first.
3. Fuel stabilizer is in the tank and system.
4. Haven't fogged cylinders yet, but this looks simple.
What I have done:
