So I need some help here guys. I'm flying back into Austin tonight where we're expecting a light freeze. I could probably throw a little heater in there and be ok tonight. But I figure nows as good a time as any to learn how to drain the water out. I also just don't want to take any chances. I have reviewed the manuals online, but since I won't be getting in until late this evening, I thought someone might be able to tell me the spots I need to address so I'm not poking around out in the cold. From what research I've done on here, it appears the plugs vary quite a bit by model and engine. On the Raptor 400 there might be plugs on the bottom of the exhaust manifolds or a hose that connects them with a blue plug. The manual says to remove the raw water pump impeller. Is this necessary? Some have said there might be a plug in the bottom of the pump. There is a plug on the heat exchanger. Also if theres anything else I need to drain I'd obviously like to know. This is my first boat and while I'm fairly familiar with engines, I have never dealt with anything on a boat. Any help would be greatly appreciated.
2015 RZ4 Texas Winter
It's going to be under the floor that lifts up on the front of the engine below the back bench seat. It is water cooled and has an intake hose coming from the bottom of the boat. There is also a strainer on that hose. I dumped the water out of the strainer too. Mine had a big drain plug on the font of it.Attached Files
Quick way to empty your ballast tanks: use a Shop Vac to suck out the drain lines (while plugging the vent lines).
On my boat, this sucks all the water out of the intake lines and pumps, too.
It would still be wise to put some antifreeze in there... Possibly funnel some in the drain lines.
Severin
I also emptied my ballast using this method and wow. There was a ton of water still in there. probably 40 gallons.Originally posted by PaceWithGrace View PostQuick way to empty your ballast tanks: use a Shop Vac to suck out the drain lines (while plugging the vent lines).
SeverinBABz - babzusa.com
Austin, TX
