Low Pressure Transmission light on dash.
    The low pressure trans light was not going off when I accelerated, it always has in the past. I check the transmission fluid level and it was full. I thought this light was just to indicate when the fluid level was low.
    The transmission appeared to operate as normal. Should I be checking something else on the transmission, or just get the sensor checked?
    Thanks.
    The switch might be bad. It is an 2lb pressure switch.
      Check the v-dive fluid level
        Is the light for the transmission or for the vdrive?
          It is for the v-drive.
            Am going to have to take the back seat out to check the fluid level or can you get to it from the engine compartment?
              Might be a good time to just change all the fluids.
                You can see it from the engine compartment. Might want to get in the storage area for a better shot.
                  I think your right, i will be doing that before a take it out again.
                    Thanks, I will try that.
