URGENT: NEED REPLACEMENT GEAR BOX COOLANT PART
    Urgently need a replacement gearbox coolant part for my Tige 2007 RZ2. I attach a photo for reference. If you know any dealers or anyone with this part, please let me know. My Tige can't run without it. I found out the old part was leaking water into the gearbox just in time to stop the gearbox getting ruined
    Appreciate your help
    Its 9 inches long (including the hose connectors)
    The hose connectors are 1.2 inches diameter
    The top holes are 0.8 inches diameter
      That part is available from seakamp engineering in seattle, 1.25" hose connections and 5/8" inverted flare oil hose connections. When you get a new one on, fill run and change at least 4 times (flush gearbox with new atf) and then recheck, pepto color still means water is present. Repeat flushing until you don't see pink anymore, run the boat on the water under load and then change again. Good luck.
