Need advice how to replace. It's not the adjuster pulley up top that is just mounted on a bracket, it's the big smooth pulley and the shaft appears to go back into the block? I removed the (4) 1/2" bolts and took the pulley itself off. Here is a photo of the pulley hub and you can see the bits of the bearings on the shaft.
This is a Mercruiser 350 in a '99 21V.
