decal material to repair graphics
    Has anyone found a decal material of the same color/material that can be used to replace a small portion of the stock decal graphics?
    A few decal tips below the waterline became unstuck and tore off. If there was a sheet of the same material, one could trace the outline from the other side and carefully apply to the ripped side. While you could see the seam if you looked close, it beats having to replace the entire graphic.
    Check with a vinyl sign company in your area. They would know where to order some with the metal flake, the guys who did my side numbers could have ordered the metal flake but I was in a rush and went with their stock black.
      ^^ Thanks!
