Hi All
I have a 2007 Tige RZ2. There are two dipsticks in the gearbox area. Both dipsticks have a red sign next to it marked ATF. My mechanic who was doing the service was used to servicing Mastercraft boats but not Tiges. The gear box can be found after removing the middle seat at the back. In the bottom dipstick, the mechanic filled it up with axle oil instead of Automatic Transmission Fluid. I thought it was odd and asked him about it. He said all Mastercrafts have the bottom dipstick on the gearbox filled with axle oil. I was not sure that this was the case for Tiges and was wondering if anyone knew the correct answer. I'm not sure my mechanic is right and I think the bottom dipstick should have been filled with automatic transmission fluid rather than axle oil
Here are some photos
1ST Photo: BOTTOM DIPSTICK WITH LABEL SAYING ATF
2nd Photo: BOTH DIPSTICKS WITH BOTTOM DIPSTICK ON THE RIGHT
3rd Photo: BOTH DIPSTICKS WITH BOTTOM DIPSTICK ON THE RIGHT (you can see the fuel line on the top)
. What do they do with the $120K they get for their boats
