Thought I'd give this its own thread. There are quite a few others where the topic of fogging has arisen but I want to make sure everyone interested sees this data.
I just got off the phone with real live people at PCM. I was asking them about their recommendations regarding fogging engines - yes or no on injected engines, yes or no on Catanium equipped engines, etc. Deborah at PCM was being very helpful and relaying the questions and answers between me and her technical folks.
Interestingly, I actually got conflicting answers depending on to whom Deborah spoke each time she put me on hold. At one point the answer was an adamant "NO". At that point, I asked how we should protect the cylinders for ~5 months if we're not supposed to fog them. Finally, I think she got tired of being the relay runner and a tech guy picked up the phone.
To the question "Should we fog our EX-343 engines?", his response was "Yes, remove the spark plugs and put in one tablespoon per cylinder." I said this was in agreement with the manual, and asked if I should then rotate the engine by hand to distribute the oil around as also described in the manual. Answer: "Yes." I asked if the reason for going through the plug holes was to avoid running fogging oil through the injectors. Answer: "Yes."
I then said that some have suggested CAT engines should not be fogged. To the question "Should we fog CAT engines too?", his response was "Yes." I then said "I understand we are to administer the fogging oil through the spark plug holes to avoid running it through the injectors. Are you saying the CAT exhaust system is not affected by fogging oil?" Answer: "Yes."
So there we have it: Authoritative answers to the questions of fogging, fuel injection, and Catanium exhaust systems.
Hope this helps!
Hope this helps!
I was just about to quote that part and question it!
