04 Tige 21i impeller with o ring.
    Hey, new here to the forum. I am having a heck of a time locating an impeller with what seems to be the right gasket as well.
    Currently the boat has a Jabsco water pump not sure of the model no. But has 4 bolts on the plate.
    The impeller removed was a 18777-001-P. When I searched for this impeller I can find the impeller 10 blade but does not include the o ring my pump has. I also noticed there are other spline drive impellers that are 12 blade with a gasket (not a o ring).
    At this point do I have to piece the together or is there another part number I can use. The current dimensions of tye impeller is 2/14 dia, 2 width.
    Thanks
