Tige Z3 rear ballast leak
    Anyone have any idea on how to access the port side hard tank under the ballast bag? When I fill the rear port ballast it isn't holding water and I can see and hear water building up in the hull causing the bilge to kick on.
    When I run the drain pump nothing is draining. I am hoping it is just a split hose or the hose at the drain pump came off and not an issue with the hard tank. I was poking my head around where the batteries are as I can hear the drain pump somewhere around there. Just not sure at what all has to come out to access the drain pump.
    Any help would be great!
