oil sucking
    oil sucking
    Anyone tried sucking the oil out from the dipstick? Has to be quicker than the slow drip of the drain line. Liquivac looks cheesy, anyone tried it?
    Been doing it for years! Works great, just warm up the engine first, than it only takes about 5 mins.
      which pump are you using?
        I just bought this mighty vac unit and hope to try it out this weekend. Just follow the link to see it. http://www.amazon.com/Mityvac-7400-L...1970831&sr=8-7
          let us know how it does..
            Hopefully I'll find out this weekend and let you know.
              Those work pretty good but I had problems getting all of the oil out in mine because the only place I could work on it that day was on a hill.
                Finally got to use the Mityvac today. I used it thru the dipstick hole and it sucked it out pretty quickly. Of course I warmed it up a little prior to trying it. Only thing I ran into, was it only pulled out about 3.5 quarts. I added another .5 quart for the filter and ended up at 4 quarts. That seemed a little low, so I went ahead and pulled the drain hose thru the drain hole and opened it up for about an hour and got a little over a half a quart more. I think what I will do next time is to adapt the Mityvac to fit the drain hose and suck it out thru the hose to make sure I get it all. All in all happy with how it worked.
                  I don't use this one, couldn't find the one I have. Mine is about 10 gal blue can that I use to suck the oil out and my Transmission oil out also. This will give you the idea.
                  http://www.cabelas.com/cabelas/en/te...box.jsp.form23
                  Dale
                  2000 21i Tige
                    Mightyvac is great! Done in a few minutes...highly recommend one.
