The Top Five Boat Battery Maintenance Tips
    I read this on another site and thought it would help. Here is the original article.
    1. If you don’t already bring your boat battery inside during the winter, you should start to. Cold temperatures are bad for batteries. If a single cell happens to freeze then you will have to buy a new one. Even if it doesn’t freeze, the battery will discharge its power like crazy in the cold. Once it is warmed up again, it will have a weak charge and it won’t be able to hold a very good charge in the future.
    2. Keeping your battery inside is a good start, but you shouldn’t stop there. Even in the house an unused battery can lose up to 30% of its charge! Therefore, you should charge it up at least once a month. This will help keep it in tip-top shape so that it will always be able to give you the power you need when you need it.
    3. Though charging your battery is important, you must remember that you shouldn’t overcharge it. On the other hand, you shouldn’t undercharge it either. Overcharging will cause the battery to corrode quicker. Undercharging it will cause a buildup of lead sulfate inside. This sort of build up will hinder the chemical reaction that makes the battery work.
    4. Using the right kind of charger is very important. Don’t use a car battery charger unless it is specifically designed to also be used on a boat battery. Instead, get yourself a battery charger made just for boat batteries. On top of this, you should make sure that the charger has a three stage charging process. The three stages are usually called bulk, absorption, and float, respectively. These stages will help optimize the charging process. The last stage especially will keep your battery completely charged without overcharging it.
    5. Another thing you should look for in a boat battery charger is the proper amperage rating. Though many chargers have a three stage process, not all of them are designed just for your boat’s battery. You need to find the charger that will fill your batteries amperage needs. A good rule of thumb is to find a charger that is rated at about 15% of your batteries amp-hour rating. Any more or any less will result in a damaged battery.
    This is why I installed an onboard computerized charger that will maintain the battery at peak performance. Park it and plug it in. No more dragging out the chargers and dealing with that hassle. Always ready to go!
      Hey Laserfish, which charger did you use? I would like to get one for my boat as well. I hate dragging all that stuff out everytime.
      Biggest lake addict on the planet
        I have a ProCharger from Bass Pro Shops. Got the small two bank as I am not charging trolling motor batteries overnight. Works like a dream.
          I think my batteries will be shot, they are originals from 2006. I didn't charge them this winter and I would like to replace them anyway. What batteries does everyone recommend? I have the dual battery setup in the 2006 24ve.
