What are all the things that need to be done in the 20 hour service? 2008 20V
20 hour service?
I can only remember a couple, manual is at my house.
replace fuel filter
change trany fluid
change oil and filter
check and tighten all engine and tranny mounts
check and tighten belts
thats about all I can remember off the top of my head, im sure there are a few more, your Tige manual explains them pretty well.
This came from a boatgears article: http://www.boatgears.net/Velvet_Drive_Tips.htmlOriginally posted by brett22i View Post...Both of mine use 30w engine oil,...
Dexron III ATF (Automatic Transmission Fluid) is recommended for all Velvet Drive and Borg-Warner Marine Transmissions. 30W-ND motor oil may be used in applications where the maximum engine speed is less than 2300 RPM. At higher RPM's motor oil will foam reducing clutch pressure. Also, motor oil does not transfer heat as well as ATF and is not recommended for use in warmer waters.
