Mildew spots on seats
    I have a used boat with what I think are mildew stians on the seats in some places. Basically just some dark spots, like water drops in some areas. What type of cleaner can I use on my seats that won't tear them up?
    In know no bleach, etc etc, that is why I looking for something made for removing mildew on vinyl. Will the Babes seat soap do the trick?
    I have had some mildew and what I used was a Magic Eraser and then put the cushion into the sun for a few hours. After I saw that the mildew was gone, I protected the seat with Babe's Seat Conditioner
      Dumb question, but are you talking about a dry erase board Magic Eraser?
        Nope...
        But take it easy with it. They aren't real gentle on vinyl, but a light use for heavy stains should be OK.
          I've also had good luck with liquid comet spray gel. It's nice cause it doesn't seem to break down the stitching like some harsher cleaners do, but seems to work better than anything else I've tried, including 3m mildew cleaner, magic eraser, ammonia/peroxide mix...just about everything. If it is really stubborn you might need to try it out.
