End of last summer prop hit rock at day camp as we were leaving. Replaced prop over the winter, engine (Merc 350 V-drive) runs perfect but can not get out of neutral (no reverse, can not get to engage into gear). Cable shifts and appears to be fine. I heard there may be a "safety" switch that kills gears in case of this kind of accident as to not ruin transmission?
Any ideas?
Any ideas?
If the mechanic said it was fine, how did he know it was okay? The mechanic should have tested the prop rotation to see if it works
is it just reverse you dont have? You say "reverse" and "gear", but dont mention "forward"
