Faria Gauge swap from VDO
    All you PRExxxx owners wanting to get rid of your cracked VDO gauges that look like Austin Powers teeth....here's your part numbers.
    ***note, these part numbers are the chesapeake white face with stainless trim. The TAPs gauge is from about an 01-02 Tige' and matches the set; one other reason I chose these other than the look.***
    Fuel Level - FAR 13801
    Oil Pressure - FAR 13802
    Temp - FAR 13804
    Voltmeter - FAR 13805
    Fuel Flow (replaced the hour meter on the right side) - FAR FFM002
    Tach/hour meter combo - FAR 33832
    2 speedos - FAR 33811
    and the TAPs I got from Texas Tige'. It matches the above except as other have mentioned as well (even the factory set of these) the illumination is a little different.
    It's part number is - #C2018
    That should fill the dash. Every gauge was mostly a swap. Some had to have new power run or jumped, and almost all were able to remove some of the lighting wiring as it is a combo on the new instuments.
    A very good source for these is www.boatersland.com; ocassionally you can get a package on ebay and save some money, but you will have some you do not need. This is a popular gauge style.
    http://www.wakeboatworld.com
    []) [] []V[] [])
    #id
    They were very helpful when my Faria oil gauge sender went out. New unit in 4 days and fixed the problem.
      #id
      Here's the VDOs
      And After
      []) [] []V[] [])
        #id
        Looks like an '08 model. Great job.
          #id
          How much did it cost to replace all of them??
            #id
            < $400
            The only reason it was so much is the TAPs and the fuel flow are not cheap at all; $100 or so each.
            []) [] []V[] [])
