Switch out tapps gauge on dash???
    I"m replacing all my gauges with Faria chrome and came to the Taps gauge and now I'm stumped. Before I disconnect it I thought I should ask the people on the best boat site around.On the back of the Tapps gauge there is a power,ground,light and then 2 little green wires. On the Faria Trim gauge there is power,ground,light and then only 1 terminal for a sender wire. Can I put the 2 green wires from the Tapps gauge onto the 1 post on my new Faria gauge? I'm not sure why there is 2 seperate green wires.
    Follow them and see where they lead too. They sound like the ground wires but you have already located those.
    For Those About To Ride We Solute You
      Taps requires 2 sender wires. You can get a replacment gauge shipped to you from Texas Tige'. I spoke with Andrew at Tige when I replaced mine. They (Tige) just used a Faria blank, and it is not the same as the trim gauge from Faria. The part number you need is C2018. It was around $110 shipped, and was the most expensive instrument in my replacements.
      http://www.wakeboatworld.com
      []) [] []V[] [])
        Thanks Spharis
