Prop Shaft Strut Bushing Replacement
    My 1995 2002 fslm needs the bushings in the prop shaft strut replaced. My guess is the old ones have to be pulled out using a slide hammer. Install the replacements by pressing them into a "warmed" strut. Am I on the right track?
    John
    John
    #id
    I have looked at mine contemplating the day when I have to do the same replacement. It looks to me like there are one or two allen headed set screws that help to hold the bushing in place. The only other one I have done did not require heat. Hope this helps.
      #id
      Thanks Tige 2K2. I called a local Moomba dealer and his response was the same. Since my boat is in storage I can't check out the strut. Yours has to be the same as mine.
      John
      John
