Change the Serpentine Belt on GM Vortec 6.0
    How to change the Serpentine Belt on GM Vortec 6.0.
    I asked this as the board went down and replies were lost.
    How do I change this belt.
    I lost one on the lake and need to know what to loosen and what the routing is.
    As I face the rear of the boat what do I do!
    Dom@ Fortes Inboard Connection If you have any questions about the belt please call me at 1 888 517 3178.
      Thank you I will be calling!
      Regards,
      Wake
        Is this the routing?
        AND
          Wake havasu
          There is a picture on the home page at www.marinepowerusa.com
          not sure if that is how youe engine is.
          Let it be!!!
            The 6.0 has a serpentine belt? The 5.7 has the old style v-belt, but MP uses dual belts and double groove pulleys. If you lose one belt, you still have the second.
              found as a result Gman's tip of PCMs PDF Parts Manual !
              Thanks to all ahow chipped in:
              Paublo, XPjim, Gman and FIC.
                If you have a pcm engine that belt routing is correct, if it is marine po wer it is routed like the picture you have of the mastercraft engine. Dom@ Fortes Inboard Connection 1 888 517 3178
