I just installed my Fresh Air Exhaust system on my 22V. I thought I would post some pictures. There will be eight posts in all as I took eight pictures and do not know how to post multiple images.
This first picture is the exhaust system straight on from the back of the boat. The exhaust tubes that are attached to the boat angle up slightly to clear the TAP-II plate.
One disadvantage of the system is that you loose the ability to quickly remove the platform. To remove it now I would have to remove four bolts from the upper bracket where it fastens to the platform and then remove the platform. But how may times have I removed my platform? Once just to see how it was done. I suspect this may be a non-issue but something that needs to be known.
Also use marine adhesive caulk on the screws. There is a gasket for the exhaust mounts so no sealant is required on them. But you do need to seal the screw holes.
Well shucks, it did not post the image. Lets try in the next message.
