Install Samson Mirror Arm 4 Alpha Z tower.
    Notice: Before removing any equipment and attempting this Install it is recommended that you have help available to handle the items your removing and installing.
    1. Remove 4 screws that hold the wet-sounds grill to enclosure. (bottom screw is behind wet sounds sticker, remove sticker and place aside for re-assembly)
    2. Mark the 4 screw holes with a sharpie that hold the speaker in the wet-sounds enclosure. (will make re-assembly much easier)
    3. Remove the 4 screws that hold the wet-sounds speaker.
    4. Remove metal ring that holds speaker in place. (be careful the speaker will want to slide out. it may seem stuck but will fall out if left un-attended)
    5. Remove speaker , There are four wires connect to the speaker document how your speaker is connected.
    6. Remove wires from speaker.
    7. Remove 2 5/16 bolts that connect speaker enclosure to tower.
    8. Once speaker enclosure is un-attached you will need to cut the yellow wire splices to remove speaker mount.
    9. Run the speaker wire through Samson mirror arm and speaker enclosure, with bolts ready to go. (you may want second person available to help hold equipment)
    10. With speaker enclosure off tower, Crimp the supplied yellow wire splices to the wires inside the enclosure. (To the two wires you cut off in step 8)
    11. Use the two NEW 5/16 bolts supplied to re-attach mirror arm to tower. Use existing washers with new bolt to secure the speaker enclosure. (Use Lock tite on bolt threads)
    12. Tighten bolts down very securely so that mirror arm and speaker do not have any movement.
    13. Crimp the wires that you ran through mirror arm and speaker to the other end of yellow wire splices.
    14. Re-Connect Speaker wires to speaker and mount speaker back in enclosure, in the holes you marked in step 2.
    15. Re-Attach wet-sounds grill and replace wet-sounds sticker on bottom hole.
    16. With arm in place attaché long section of the Samson mirror arm.
    17. Remove 2 allen bolts from the plate on mirror arm. (the ones that are for the cover that hides the mirror bolt and nut)
    18. Attach mirror to arm. 7/16 wrench \ socket is needed to secure the mirror to arm.
    19. Re-assemble cover that hides mirror bolt and nut.
    20. Your done! Hit the lake and Enjoy!
    2011 Tigé RZ4
    www.re-viveupholstery.com
    Just as described - it is a pain in the arse to get it all mounted, but worth the work.
      ok..we like pictures!
      Nick
      Dayton, Ohio
        Pictures please. Can't get the speaker cover off. Outer shell easy, but the next section is not moving. ?hammer time
        Warhagen at yahoo
