I just noticed a thread that showed a ballast install. The author cut a 1" hole using a holesaw in the side of his boat and installed a bulkhead fitting. Very clean cut.... except I didn't see any bevel in the gelcoat. Without a bevel, he will experience cracking in the gelcoat. Always, when drilling or cuting a hole in a gelcoat surface, bevel back the gelcoat. For drilled holes, use a countersink and bevel just past the gel into the fiberglass. For holesawed holes, use a fine half-round file, and bevel just past the gel to the fiberglass. This breaks the sharp edge of the hole and prevents the brittle gelcoat from stress cracking.
When drilling or cutting gelcoat...
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
Also use tape over the place you are going to drill through...Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
Tigé Jedi- Jul 2010
- 4305
- TN USA
All good pieces of advice. I just cut eight one inch holes this afternoon (for drains and vents) and all went well thanks to the above steps.
I used to run the drill/saw in reverse all the way through, but a while back I moved to the "just through the gelcoat" approach. It works fine and is MUCH faster. Then a little emery paper to bevel the edge and you're good to go!
I'll add one more: If you're using a hole saw and care about what the backside of the hole will look like, cut about halfway through and then finish by cutting from the other side. The pilot bit in the hole saw will insure you line up perfectly, and you'll get a nice clean edge on both sides.
Tigé Expert- Sep 2007
- 2409
- Manitoba Canada
- '06 Wakesetter VLX, Prev '06 Tige 24V - '03 Tige22i - '99 Sunsetter - '99 Tige 21i, -'96 Ski Chall
Heres a further tip...when your drill for your discharge thru hull hole just drill enough to have the 1/4" pilot bit to go all the way through the hull. Now from inside if you have access, use a 2" hole saw JUST TO CUT THE CARPET, then go back to the outside just to finish your original 1' hole. You now have a very professional looking job and your thru hull nut can be screwed down right the hull. How many times have you seen a crappy looking square notch of carpet cut for the round nut??Originally posted by WABoating View PostAll good pieces of advice. I just cut eight one inch holes this afternoon (for drains and vents) and all went well thanks to the above steps.
(NB. You may need one of those 90 deg chucks.)Life is good...
Happy Wife Happy Life
