How to add hydraulic fluid to a Parker EHA actuator
    Hi all,
    Starboard side actuator got stuck in the fully extended position. The fill/relief cap was removed in order to get the surf plate up and the cylinder retracted. Some fluid was lost in the process. How do i go about adding fluid?
    The relay stuck and that was the root cause of the tab being stuck down.
    2021 parker EHA actuator
    Thanks!
    #id
    I have no idea what year boat this is on and what a Parker EHA actuator is. Tige has been using electric actuators for a number of years now.
      #id
      Sorry for the lack of information
      2021 rzx23
      parker brand
      electric hydraulic actuator
        #id
        https://ph.parker.com/us/en/compact-...aulic-actuator
        ^^instruction manual pdf is at the bottom of the page
          #id
          Cool, did not realize it was electric pump driven.
            #id
            2021 rzx23
            parker brand
            I would also be concerned about the clip missing on the clevis pins.
              #id
              Nice spot Lee
                #id
                on they went, till the activity was pretty done, and the footwear stood equipped to be used upon the desk. this become long before dawn; and then they bustled away as short as lightning.
                voip phone service
                  #id
                  did you ever figure out how to add fluid and bleed it?
