Service Manuals...where to get them
    Where can I get a service manual for a 98 2200V?
    Thanks
    Bakes
    #id
    not sure, you might wanna try calling or writing the factory, they might have a few laying around, other than that maybe someone on here has the same boat and can make a copy for you, GOOD LUCK
      #id
      There really isn't an all-inclusive manual for boats because are assembled with parts from soooo many different vendors. The hull is pretty much the only thing a boat builder actually makes, the rest is purchased and assembled at the factory. Is there a particular system that you need info on
        #id
        Here is a service manual, not sure if this helps or not.
        http://tigeowners.com/downloads/Tige_Service_Manual.pdf
          #id
          Bake,
          I'd also recommend getting the SELOC manual for your motor. The manual will cover both stern and inboard drive boats. I think I got mine for around $40 from WestMarine.
          If you plan on doing maintenance yourself, I would recommend it.
            #id
            I can probably help with a motor workshop manual, let me know what motor you have fitted.
              #id
              If you have a Merc. you can get a manual.
              https://appcenter.mercurymarine.com/...rm.jsp?type=mc
