New Tige Owner
    New Tige Owner
    Just purchased a 2005 Tige 22v. The previous owner gave me a complete set of books for everything in the boat. Two items in the Tige bag i found i have not an idea what they are for.
    1. Looks Like a Brass Key approx 2 inches long and has a ball bearing and spring in it. Looks like it inserts in something.
    2. Black plastic Cap Looks like a gas cap has Airmar on the top.
    3. Boat has controls above throttle for the heater and a a number of heating outlets thruout the front of the boat but with key on i don't feel anything coming out. Does the boat have to be started first.
    Thanks,
    doug
    Also is it possible to hook a hose anywhere and run the boat in the driveway similar to what you do with sterndrives?
    #id
    Welcome!
    Post some pictures if you can. Of the boat and the parts you questioning.
    Here is a post that will help you with the running the boat on the driveway. Don't put it in drive though, just run the engine.
    http://www.tigeowners.com/forum/showthread.php?t=9204
