Cavitation
    #id
    Originally posted by TRD View Post
    You are RIGHT!!!!! Also for easier shaft removal.
    Props to TIGE customer service. I call Tige and spoke to someone about and he ALL Tige's have an offset. (I didn't know if I was a loud to post his name so I didn't).
    THANKS TIGE FOR THE CUSTOMER SERVICE, called me back w/in 15 minutes. That is 2 in one wk for them.
    Cool. BTW, Larry Mann has a Tige 20i. So, I'm sure your FAE will be dialed in for your boat.
      #id
      Tried calling earlier today but had to leave a message. Haven't heard back from him yet. Have some work to do today.
      Dale
      2000 21i Tige
        #id
        Just got a voice mail from Larry and will talk to him later on tonight.
        Dale
        2000 21i Tige
          #id
          Originally posted by samw View Post
          I don't think so but will check tonight. But I do have v drive.
          TRD, I checked my rudder and it is dead on with the shaft so on offset...
          Sam
          15 Escalade ESV-Black
          08 RZ2-Blue
            #id
            Back in the day, the 3 blade 13X13 was pretty standard on the tournament direct drives. Then OJ can out with the 4Force, the 4 blade prop that was the rage in the mid to late 90's and even early 2000's.
            When CNC props came about from ACME and then OJ. They could get more surface area so the 3 blade CNC prop was the choice for direct drives. And the pitches changed. I don't know exactly how that works. But a 13X13 OJ legend and a 13X12 OJ CNC prop have similiar RPM ranges.
            All this is a generalization about tournament direct drives. Not the bigger direct drives and v drives.
            Malibu Owner, but I like Tige's too
              #id
              I was just wanting to know is it worth the money to get my prop fixed? I do want to get a new prop now that I have read dogs other post. W/ just putting a new stereo and speakers and a FAE to the boat I need to wait a bit.
              Has anyone every heard of this place? Barnacle Boulters Diving & Propeller
              Dale
              2000 21i Tige
                #id
                From what I can see in the picture it is definitely worth the difference in performance to have the prop refurbished. You've been using it anyway, just send it off after you winterize and you'll be ready next spring. If you decide to buy a new one next year you'll have a good spare on-hand.
                  #id
                  Great, this is what I was hoping for.
                  Thanks
                  Dale
                  2000 21i Tige
                    #id
                    My 2001 22i type R had a 4 blade from the factory as standard with the Black Scorpion engine.
                      #id
                      would these dings make the boat cavitate when turning or at slow speeds. I noticed that I had some vibrations and cavitation this wkend.
                      If so, Is this something that can be fixed or will I need a new prop?
                      I had less damage on my Acme 537 and it would vibrate the floorboard.
                      I installed my backup prop, and problem fixed. Sent the prop to Acme to have it straighten and balanced. Was told it will make it as good as new. Cost 150. have not tried it yet, as I set it aside as my new backup. (I always take a backup to the lake. Hate to drive 3 hours and cut the day short due to a prop issue)
                      Tige, it's a way of life!
                        #id
                        TRD
                        I would take the advice of whoever said buy a new acme 3 blade and get that one fixed as a spare, assuming you have the gear to pull and replace for a weekend saver. Our 99 21i hit hard 2 years ago and we did the alignment, fixed prop(factory SS 13x13), shaft, bearing and strut. Not as quiet/smooth as it was before even though (I think) it should have been better. The prop fix was the least expensive of it all and it is my uneducated opinion that we should have gone for a new prop at that time and kept the repaired one as a spare. Also realized that the rudder is offset on purpose for the rotation and getting the shaft out. By the look of your pics I'm surprised your boat doesn't roar.
                          #id
                          When you're ready for that new prop, Dale, give me a shout!
