speed control
    speed control
    I was in Powell last week and had a chance to board behind my brother inlaws 247LSV with the speed control.It ruined me for my boat.I have a 98 PRE2200WT.Do you guys know what my options are for an add on speed control ?
    You bet wakeboarding and motocross will drain the wallet in a hurry ,but not near as fast as teenage rehab
    #id
    Perfect Pass
      #id
      diddo, Star Gazer Wake Edition $1195. This will probly be your best bet. You can even install it yourself.
      Tige Throws Mad Wake.
        #id
        I just noticed that the New PP systems are GPS based instead of paddle wheel
          #id
          Yeah the Stargazer.
          Common Sense is not so Common
            #id
            If we could get 5 of us that want to buy the PerfectPass Stargazer Wakeboard, we can get a discount with Ian from Only Inboards. I stll haven't pulled the trigger but I am growing tired of the inability of my wife to drive a consistent speed.
              #id
              PerfectPass When it doesn't work, I don't even want to go out on the boat.
                #id
                The cool part is you can upgrade current paddle wheel pefect pass to the GPS system. Granted it will set you back $600-$800, but I like knowing I could upgrade if the current system ever acts up.
                  #id
                  Depends on how old your system is. Some may have to upgrade, the screen master module and add the gps stuff.
                    #id
                    http://www.perfectpass.com/pp_star_gazer.html#upgrade
                    As long as you have wakeboard pro you can upgrade: $429 for the module and $199 if you need the new display. Still seems like a good deal to me.
                      #id
                      After mashing my paddle wheel twice this summer, I'm thinking about it.
                        #id
                        I am not sure if it is available yet, but I recommend Zero Off over Star Gazer. They are using both systems in 3-event skiing & as a driver, Zero Off is much easier to use over Star Gazer.
                        http://zerogps.com/index.php
                          #id
                          But I don't think Zero Off works with our older NON drive by wire (we have mechanical).???
                            #id
                            You are correct
                            What boats will Zero Off be available for?
                            Currently the Zero Off speed control system only works on 2006-2008 boats with a drive-by-wire, GM 5.7L & 6.0L engines that use an eControls ECU.
                              #id
                              Dont buy Zero off unless you are a tournament skier. If you want GPS speed control for wakeboarding use PP
