Swim platform rattleing
    Has anyone else had the problem of the swim pltform having much play up and down?? I looked how it is made and the design seems to well "suck". The grooves on the brackets are worn and there are only 2 pins that hold it together. Any suggestions..
    #id
    Welcome to site.
    What boat do you have?
    It sounds like you have a quick release swim step. Is it a teak or fiberglass?
    How about a picture of your setup? That will help the most.
      #id
      The platform on some models that I have seen do rattle a lot. I think tigeblue has filled the gaps with silicon to stop it from rattling. My platform does rattle on the RZ2 but I haven't had time to fix/play with it while the 24Ve never rattled.
        #id
        Mine just started to rattle. I may try a little larger bolt.
          #id
          I have a 2002 Tige 21V riders edition. My platform is Teak. It is a Quick release. I got very frustrated with the vibration. Bigger pins will not solve the problem. However I did something that has woked okay for a few days now. THere is quite a bit of aluminum in the bracket that is thru bolted to the boat. So I drilleg a 1/4 in deep hole in the aluminum only, not the HULL. I tapped and helicoiled it. I then matched up the holes in the bracket to the platform brackets and drilled a slightly larger hole. I never seized three stainless steel bolts and lockwashers and bolted in it the the bracket. 3 bolts total + the 2 pins. ROCK SOLID now. THe question is will it last? It took me about three hours with the boat out of the water.
            #id
            The silicon trick works pretty well.
              #id
              One of the brackets broke, the step torqued, and bent the other bracket. The swimstep fell off. Its a 2003, teak. Anyone know how to replace or retrofit the bracket. My dealer doesn't know if i can replace the bracket.
                #id
                Unknown.........Maybe a good machine shop can fabricate something out of an aluminum block??????
                  #id
                  http://www.wakeworld.com/MB/Discus/m...tml?1217362854
                  3 links in that thread:
                  http://www.alloymarine.com/qrs.shtml
                  http://www.boatwoodwork.com/brackets.html
                  http://www.woodworkingforwatercraft.com/bracket.html
                  "the plural of boo is booze."
                    #id
                    mine doesnt rattle but it does flex a fair bit.
                    looking at the mounting tho, you would need a tremendous amount of force to pull it from the hull.
