fake-a-lake
    fake-a-lake
    looking for a fake a lake w/a hook to hold the unit to the bottom of the boat. no pole!
    #id
    Where do you find them and how much are the?
    The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
      #id
      thats my question.
        #id
        the only thing I found close to that is for a I/O. Perhaps someone cut the wire and made a hook. (Click here for more Info)
          #id
          I used a plunger and some garden hose fittings to make mine, cost like $6 total....
            #id
            $4 Home Depot plunger and a 2x4 as a shim work perfect for me.
              #id
              I don't need one on my 07 20V. I hoke a standard garden hose to a fitting in the engine compartment, push a lever, turn the hose on and I am ready to go.
              I have no idea what option gave me this but it is nice. It might have been the Flush kit(Weed Strainer)option which was on the stock model I bought.
                #id
                I did the same as most ppl here. made a hole in the plunger cut the pole to the right length and wedge it up under the lake
                  #id
                  I was lazy, I cut a 3/4" hole for the hose in a clear GLAD container and stuck a 2x4 under it.
                  Honey I'm home!
                    #id
                    I could only find the one with the pole. Maybe watch e-bay.
                      #id
                      the problem w/ the plunger type is it will tend to move off the water pick-up when you get in & out of the boat.
                        #id
                        I plumbed a hose connector in the raw water side works great also great for winterizing. since my PCM ZR6 is a closed system I just blow the water out and add antifreeze
                          #id
                          Pics!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                            #id
                            I'll get some up today
                              #id
                              I bought bought the Moeller unit off of Amazon.com for $25 shipped. Looks just like the fake lake, works perfect and doesn't move. For $25 it was worth it not hasseling making my own.
