Block drains 2007 22ve
    #id
    Good point Scoot.
    Those things are tough to get to through the access hole unless you have 2 elbows.
    I agree with that, I just remove the center seat section to gain access to all of that. I have got the trick down to a science to getting to the lower inside bolts out to make for quick and easy removal of that seat section. Once that is out of the way the bildge is wide open, makes the whole process much easier.
    I don't want to go to work, take me wake surfing instead!
      #id
      On mine, I have a fuel cooler line that has a drain plug built into it that makes it relatively straightforward to drain because it's lower than the V-Drive and transmission.
