this is getting old......
    i have a 2002 22i and when im at 3/4 to full throttle it runs great but from pulling some one up to 21 on the pp it sounds and feels like it is missing. im thinking it might need a new distributer cap and wires for a tune up.. after running the boat for an hour or so it will run fine. or i will mess with the wires and twist them around , un do them from the distubuter cap and put them back on and it is fine again for a while.. any thoughts? i bouth this boat used a couple of months ago and had 590 hrs. on it and now has like 610 on it.
    #id
    You may need some new plug wires. My dealer recommended new plug wires at 400 hrs. Perhaps they were never changed.
      #id
      Does sound like an engine miss. Start with the cheap and easy stuff; plugs, plug wires, Distributor cap, rotor, fuel/water separator filter. Use Marine grade, not automotive.
      You are talking about plug wires right?
        #id
        I'd guess it was plugs, plug wires or distributor cap. Pretty easy and quick fix.
          #id
          If you can, take pictures of the old plugs and post them here as well. Is that engine fuel injected?
          http://www.wakeboatworld.com
          []) [] []V[] [])
            #id
            350 merc. mpi
              #id
              BTW, the reason you replace the plug wires at 400 hours is that they tend to heat up and then end up misfiring.
                #id
                oh .. ok.. i didnt know that. thanks for the info. im going to the shop to get some stuff now.. thanks again
