TAPS guage different color then rest
    Hello Folks,
    The TAPS guage backlighting on my 24V is different then the rest of the guage cluster lighting. Is this the way its supposed to be? Just wondering if it is supposed to match...
    Thanks!
    #id
    Yup, My 2003 is the same way. They are all red, except the TAPS is white.
    Common Sense is not so Common
      #id
      It is even a different color from other Faria gauges from the same model line. It is the color of the plastic the light shines through.
      http://www.wakeboatworld.com
      []) [] []V[] [])
        #id
        My 2000 is the same way.
          #id
          Tks folks - thought the 'bulb' needed to be changed!
            #id
            Hmmm...mine on my '03 20i looks similar to the others....
            Mike
            Ambivalent? Yes. Or Not.
              #id
              Mine are different too. Gauges are red and the TAPS appears to be green.
              "the plural of boo is booze."
                #id
                I have an 04, and they all are white.
                I want to change them out to use a red bulb, has anybody tryed chaging the color of the light bulb on the them yet?
                Tige, it's a way of life!
                  #id
                  The bulbs are a regular incandecent, so you could swap them over to a similar style LED replacement. They use the same twist lock type bulb as Chevy uses on instrument panels.
                  []) [] []V[] [])
