Im thinking about installing underwater lights on my ‘14 RZR with Tige Touch. I have a touch option on the switch screen for the lights, can lights be wired to operate off that screen? I do not want to add actual switches. Thanks in advance for the feed back.
Underwater lights
Yes, no need to mount and wire a physical switch. However, you may have to enter the dealer mode and activate the switch. This is common among many brands these days with un-ordered factory options. The next thing to consider, what amount of load will the system handle? Its at least designed to handle the load of the factory lights.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I dont. Most are going to interfere with the movement of the plate. You may even find that you have to dismount the actuator to get it in and out. Lastly, taking the drain plug lights in and out leads to harness failure.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I recommend this one, Blue or Green is really cool in water
https://www.imarineled.com/27w-1800-...oat-light.html
@williamGOriginally posted by williamG View PostI recommend this one, Blue or Green is really cool in water
Welcome to the forum. Tell us more about your boat that this light is on. Whats the clarity of the water you boat in. What do you recommend this light over others based on your experience?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Your site advertises that your lights have the lowest current draw in the industry. Sounds great on the surface. However, out in the field, we have found that current draw is the best means we have to gauge a light's brightness. So here's my conundrum. a 1A draw tells me your light is not bright at all. Although we dont put much stock in advertised lumens, your 1300 rating, puts it inline with lights we were using 10 years ago when the underwater LED as in its infancy.Originally posted by williamG View PostI recommend this one, Blue or Green is really cool in water
Ive stated my concerns with thread-in plugs lights in many threads, including this thread.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Here is what it looks like with the boat, I'm satisfied with the brightness.
Originally posted by chpthril View PostYour site advertises that your lights have the lowest current draw in the industry. Sounds great on the surface. However, out in the field, we have found that current draw is the best means we have to gauge a light's brightness. So here's my conundrum. a 1A draw tells me your light is not bright at all. Although we dont put much stock in advertised lumens, your 1300 rating, puts it inline with lights we were using 10 years ago when the underwater LED as in its infancy.
@William,Originally posted by williamG View PostHere is what it looks like with the boat, I'm satisfied with the brightness.
[ATTACH]47574[/ATTACH]
Who is Jeremy? He's over on wake world right this very minute passing that boat off as his. Also, that boat is found on an amazon sales add for some lights? Really your boat?
http://www.wakeworld.com/forum/showthread.php?t=806612
https://www.amazon.com/Anti-corrosio.../dp/B00QF073ZOMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
There’s a couple write ups on mounting lights to brackets on the Vx plate so the lights are on the back of the plate and nothing is blocking their output. I think member Blackoutatx had a pair of shadow casters mounted like that that he swapped out to the new bad boy Liquid Lumens. He could steer ya in the right direction on the brackets.Originally posted by Brianrzr View PostI have the VX hull extension, and I’m thinking about using a light that uses the drain hole. What type do you guys recommend?
I sure did. They worked great. PM me if it's something you think you want to try. Its not a hard job at all.Originally posted by Jetdriver View PostThere’s a couple write ups on mounting lights to brackets on the Vx plate so the lights are on the back of the plate and nothing is blocking their output. I think member Blackoutatx had a pair of shadow casters mounted like that that he swapped out to the new bad boy Liquid Lumens. He could steer ya in the right direction on the brackets.BABz - babzusa.com
Austin, TX
CHP GOT EM!!!!!! Hes silent now. LOLOriginally posted by chpthril View Post@William,
https://www.amazon.com/Anti-corrosio.../dp/B00QF073ZOGermaine Marine
