I have a 1998 2200VE with a very leaking prop shaft. I pulled the kotter pin loosened the big nut and found ONE piece of synthetic packing rather tan the 3 pieces I expected. Anyone ever run into this? Also the fluid in my Warner pump is "milky" does that mean water has been where not supposed to. What is the correct fluid for the Warner drive.
V Drive prop shaft leaking
