Gas cap leaking???
    Gas cap leaking???
    I have a 1994 2002 fslm and just recently when on the trailer and parked on a slight up grade gas is leaking from the gas cap or in that area. I have replaced the o-ring on the gas cap and still have the problem. Any ideas?
    Well you did the only thing I would have tried. Hopefully someone else will have another idea.
      Even full to the brim the cap shouldn't leak. Sounds to me like you may have a blockage in your vent line. It should be letting that pressure out. Maybe the vent hose is pinched somewhere?
        I agree with Jetdriver that the vent probably is blocked.
          Agree with above. Gas cap leaking or is it the breather vent that leaks? I know when full I'll spill gas going up our summer house driveway through the breather.
