How many qts of oil should you use to refill a 2013 Tige Z1 with the PCM EX343 engine after it is drained?
EX343 Oil change amount
Tigé Jedi- Jul 2010
- 4274
- TN USA
I have one full and one partial gallon jug of Rotella T (now Rotella T4) 15-40W oil when I do a LOF. Start with the partial, it uses most of the full, and the latter becomes your partial 50 engine hours later.
Remember to fill the filter with fresh oil, and give the oil a chance to soak into the filter element (takes a couple of minutes), then top it off before screwing it into place.
