Battery
    Battery
    My 2015 ASR is my first boat with all the bells and whistles. Simple question to start, what should be the reading on house and crank on a full charge?
    12-13 volts is usually what I see on full charge.
      On a new wet cell battery with little no cycles, 12.8 is a full at rest state of charge. However, what you see on a used battery and on the helm gauge may be lower. could be 12.3-12.5
        My crank battery will frequently read under 4 volts on Tige' Touch, but it never fails to start the boat. Once the boat is started it reads 12+ volts.....go figure. Needless to say, I've learned NOT to trust the Tige' Touch when it comes to voltage on my crank battery. The House battery almost always reads 12+ volts. Mine is an early production '14 Z3.
