beeps twice-engine dies
    Help replaced PCM, replaced all filters, one fuel pump-does this when hot out when you want to use boat. I am sure it is hot in Texas so not all 2003 21i with 315hp efi cannot run. Merc rep says it is the gas so what else can I do boats that die while doing inverts are just plain dangerous- I have had this problem for a year now please I need help
    #id
    I have the same boat.I had a problem that was traced to main elec.conector at rear of engine.Pull it apart and split prongs,shoot some elec. cleaner in and reclamp.My problem was deferent then yours though I would see if this helps.
      #id
      Possible Fix
      Kevin,
      My boat kept dying for what seemed to be no reason. I replaced the ALternator, Plugs, Wires Etc. (2003 21i with 90 hrs). Nothing would work.
      The main wiring harnes was the problem. In the very back of the engine there is a big round plug with a silver clamp around it. Make sure your batteries are off. Take that plug out and you will notice the 8 prongs. Split them apart, so that they look a little too wide. Stick that sucker back in, and I'm 90% sure your problem will be fixed. It sounds like your boat is acting like the ignition is dying. This wiring harness controlls the entire front of the boat.
      Let me know if this helps.
      Wes
        #id
        where about on the back of motor is plug I have not looked yet is it real easy to find?
          #id
          It is easy
          OK, the plug is located on the very back (towards the Drivers side) of the boat. It is Black. It is not one of the many white square plugs that you will see around the engine. Just look for the big rubbery round plug in the back with a silver tightening band around it. Be sure to get that plug put back on real tight, perhaps even use some zip-ties.
          Good Luck,
          If you need to you can call me and I can walk you through it.
          Wes
            #id
            Thanks it has not stalled since I tightened and cleaned plug but it has not been very hot. The one thing it does still do is somtimes it just kind of slowly idles down and stops.
              #id
              Enhancing Connectors
              Try using this stuff on the connector. It provides insolation between contacts and improved conductivity contact to contact. I have used this stuff on computers for years and it has solved many problems. I see no harm in using the stuff on the boat connectors. The company also makes some contact cleaner that is pretty good. After treating the contact coat the connector with dielectric grease to keep out water.
              You can buy the stuff at Radio Shack.
              Ray Thompson
              2005 22V
